Wheel Alignment
Keep Your Ride Straight with a Four-Wheel Alignment at GB AUTO BODY
GB AUTO BODY is committed to keeping your car running smoothly and on the road. After all, preventative maintenance is crucial for any vehicle. That’s where our four-wheel alignment service comes in.
What is a Four-Wheel Alignment?
Unlike a two-wheel alignment that focuses solely on the front wheels, a four-wheel alignment inspects and adjusts the positioning of all four wheels. This ensures they’re angled correctly relative to the road surface and each other. There are three key measurements involved:
- Camber: This refers to the tilt of the tires, either inward (negative camber) or outward (positive camber).
- Toe: This indicates the direction the tires face, either pointed in (toe-in) or out (toe-out).
- Caster: This is the angle of the steering axis, influencing how the wheels return to center after a turn.
Proper alignment of these angles is vital for optimal vehicle performance and safety.
Benefits of a Four-Wheel Alignment
Regular four-wheel alignments offer numerous benefits for your car. Here’s how:
- Extended Tire Life: Misaligned wheels can cause uneven wear on your tires, leading to premature replacements. A four-wheel alignment prevents this, saving you money in the long run.
- Improved Handling and Stability: Properly aligned wheels ensure your car tracks straight and responds predictably to steering inputs, enhancing overall driving control and stability.
- Enhanced Fuel Efficiency: Misaligned wheels can increase rolling resistance, reducing your car’s fuel economy. A four-wheel alignment optimizes fuel efficiency by minimizing rolling resistance.
- Reduced Tire Noise: Misaligned wheels can sometimes generate vibrations that translate into unwanted road noise in the cabin. A four-wheel alignment can quieten your ride.
Signs You Need a Four-Wheel Alignment
Here are some indicators that your car might be due for a four-wheel alignment:
- Uneven Tire Wear: If you notice your tires are wearing unevenly on the inside or outside edges, misalignment could be the culprit.
- Pulling to One Side: Does your car tend to drift or pull to the left or right while driving straight? This is a classic sign of misalignment.
- Off-Center Steering Wheel: If you have to hold the steering wheel slightly off-center to maintain a straight line, your wheels might be misaligned.
- Recent Collision or Suspension Work: If you’ve recently hit a curb, been in an accident, or had suspension work done, a four-wheel alignment is recommended to ensure proper positioning.
GB AUTO BODY: Your Trusted Partner for Four-Wheel Alignment
At GB AUTO BODY, our certified technicians use state-of-the-art equipment to perform comprehensive four-wheel alignments. We ensure your car’s wheels are perfectly aligned, maximizing tire life, improving handling, and keeping you safe on the road.
Schedule your four-wheel alignment appointment with GB AUTO BODY today! We offer competitive prices and exceptional service.
Contact us via email or call us at 818 875 3331 to learn more!
I recently brought my car to GB Auto Body to fix a door ding. I dropped it off on Wednesday and picked it up on Friday. Not only did they flawlessly repair the door ding, they went above and beyond to make my car look better than the day I bought it.
Norik and the team were extremely friendly and helpful throughout the entire process. Their professionalism and attention to detail were evident from start to finish.
This experience has been one of the best interactions I’ve had with any business in years. I highly recommend GB to anyone in need of car repairs or detailing. Their dedication to customer satisfaction is truly commendable. Thank you!!
My car was damaged due the highway accident, and GB Auto Body helped me to make an estimate for insurance and fix the car. Will highly recommend them to anyone!!! Best quality and easy communication
Roberto and Suzie have been angels! Suzie has helped me coordinate times for estimates, drop-offs, and pick-ups seamlessly. She has been so informative every step of the way. And Roberto went out of his way (even staying past close) to make sure that I was driving a safe car that would not be ticketed. And the total cost was half of what I was quoted elsewhere! Finally found a shop I trust 🙂
